matlark Member M Join Date Jul 2011 Location KY Posts 102 May 22, 2012 #1 Anyone know the byte capacity? I was comparing the AB ML 1200 to the idec FC5A series and can't find that info. IDECS is up to 128KB. thanks
OkiePC Lifetime Supporting Member Join Date Mar 2005 Location ENE of Nowhere Oklahoma Posts 11,794 May 22, 2012 #2 The user program memory in a Micrologix is not expandable. In the 1200, I think you get 4K for logic and 2K for data storage. The separate memory module is for non volatile storage. See pages 8 and 9 for the 1200: http://literature.rockwellautomation.com/idc/groups/literature/documents/sg/1761-sg001_-en-p.pdf Looks like some of the other models allow for data logging and recipe storage, but not the 1200.
matlark Member OP M Join Date Jul 2011 Location KY Posts 102 May 22, 2012 #3 I currently load programs on a test rig, then load eeprom (memory module). So I need to know the size of the memory module. As long as the AB memory module capacity is smaller than the IDEC 128KB I should be fine.
