AB micro 1400 remote programming
roburn1
Mar 2011
Queensland
Haven't had to do this before.
Can anyone tell me the procedure to setup remote programming of a micrologix 1400 with RSlogix500 micro. PLC unit is installed in another country (PNG). Will soon have a broadband router at the PLC end with static IP address.
The right way to do this is to buy a VPN appliance, I use the Sonicwall TZ100 almost exclusively. Then you just connect to it and you're on the same network as the 1400. You could just use port forwarding from the broadband router to the PLC but that isn't very secure.
I will second that advice. We use sonicwall products here and they are real good and have great support.
We use TZ200 series for what you speak of and sonicwall has a option where a sonicwall engineer will help you setup everthing by remote for a 250.00 Fee if you need that kind of help.
We use tofino units also http://www.tofinosecurity.com/products/Video-The-Tofino-Industrial-Security -Solution
They are easy to setup and are made for control systems and industrial enviroments. They are din rail maount and hardened for the plant floor where the sonic wall is not.
We use tofino units in the cabinets and sonicwalls for Zone control in the various wiring closets / rooms.
From watching the video, the Tofino unit provides security. Does it also have remote access capability or is it just for security? How do you use it?
Hello, I Have A Allen Bradley 1400 That I Would like To Remotely Communicate With. WI-FI IsAvailable On The Remote End. I Don't Want To Use Any...
3,019
Hi! Last few I've been trying to send message from MicroLogix 1400 to Micro 850. Unfortunately every time I failed :banghead:. Did someone tried...
3,195
Hello, There was a mix up in information on some redeployed equipment and two of the micro 1400's that came in were hooked to 120v when they...
1,961
I am trying to exchange data (N registers) to and from a Control Logix PLC. I am programming the messages in the Control Logix program, to...
2,176
Does the 1100 only have 1 high speed counter, but it can have multiple inputs? And so then the 1400 has 6 HSC and you have a choice of multiple...
1,723
