AB Micrologix PV PID Issue
RS Haldini
Sep 2014
Richmond VA
I cannot get the PV to show up in the Setup Screen of a PID instruction using Logix 500. I am using N7:0 as the Process Variable integer word. I have tried in both a ML1500 and ML1400
Explain what you mean by "show up".
Post your program if you can. Its .RSS file, zip it first.
same problem.The scaled value of PV is showing in the logic outside PID setup correct wheras in PID setup screen the PV value is proportionately small..Any soultion ?
Keep in mind the Set point and the PV must be the same units in a PID control
PSI , Level or just raw numbers the PID control will do whatever it need to do too by changing the output to make the PV = Set point within the range
I've got a control loop that I can't quite figure out how to accomplish. Three variable speed wells feed water to a tank, the tank supplies water...
4,015
HI - I have a tough process and have been struggling with controlling my PV using a Micrologix 1400. I uploaded the file, changed .rss to .txt...
2,006
I have 2 no.s Micrologix PLCs used for PID control variable output to 7 no.s VFD drives.2 no.s are used as i have no spare analog cards for analog...
1,534
I'm trying to get my PID function to go into manual mode and give the CV a value through a MOV instruction. I can set the Auto/Manual bit, and the...
1,657
Hey guys, After spending most of a day Googling looking for the answer, I finally decided to make a thread and ask the experts. I'm trying to...
3,575
