Micrologix 1400 PID logic
Ghouse
Oct 2018
bangalore
I have 2 no.s Micrologix PLCs used for PID control variable output to 7 no.s VFD drives.2 no.s are used as i have no spare analog cards for analog outputs.I have used a refernce signal of 4-20 mA( 500 ohm res. across analog input is placed for voltage ) for analog input and logic developed with appropriate scaling to engineering units.Now the program worked well with PID parameters tuned with the help of trends pens and output is almost linear with setpoint.But suddenly i saw 2 problems
1) With variation of PV from 4-20 mA refernce the output almost got stagnated either at lower limit or upper limit irrespective of error.When the error is more the control outpur still sat at lower limit( 50%)
2) The reference signal to these 2 PLC's is from same source and signal multiplier is used with appropriate tuning of outputs.
Now for suppose i am running 1 and 2 VFD from ML 1 and 3,4 from ML 2 will there be any problem in the execution of PID in these 2 PLC's?
P.S. : No conditional logic used for PID.
The snap is enclosed for reference.Please help me out.Thanks in advance.
One issue might be Output max CV % set to zero.
edit: Nevermind: Output limiting is turned off.
HI - I have a tough process and have been struggling with controlling my PV using a Micrologix 1400. I uploaded the file, changed .rss to .txt...
2,007
in micrologix 1400 we have to enter duty cycle to get particular duty cycle.But i want my duty cycle changes according to values coming from pid...
2,627
I am having trouble with PID instruction. I have done this many times with a SLC500 but not with the Micrologix 1400. Basically I am confused on...
3,152
I've got a control loop that I can't quite figure out how to accomplish. Three variable speed wells feed water to a tank, the tank supplies water...
4,015
First time using a PID instruction on a micrologix 1400 Platform, my issue is putting the PID instruction in manual and writing to the CV for...
4,457
