AB MLX 1400 PLC communication with LABVIEW
Jul 2012
tn
I want to know the pin configuration to communicate AB MLX1400 with labview through channel 2 (9 pin connector) in modbus RTU slave mode.
Also in if we configure AB MLX 1400 in modbus RTU master then how to read the data from LABVIEW
There is nothing special about the serial port ( 9-Pin channel 2) on the ML1400. Standard RS232, a null-modem cable should work just fine. See picture.
How far apart are the ML1400 and PC from each other?
SCADA/HMI systems usually do the polling, so leave the ML1400 as a slave. Note, I have not used LABVIEW.
hi mickey
distance between them will be 10 meters...
HELLO BOYS, I HAVE AN INTERROGANT, HOW CAN I MIGRATE A PROGRAM FROM A PLC MICROLOGIX 1500 TO A PLC 1400:beerchug:
1,633
Hey Guys, I am struggling to read data from a "JUMO" make controller using modbus RTU with MLX1400. The communication between the devices has...
18
5,086
Newbie question here, I have been trying to setup a Ethernet/IP network consisting of 3 AB Micrologix 1400 plc's, one Idec HG4G-CJT22MF-B OI, and...
3,335
I was talking to a customer on the phone. Sick kids so I couldn't get on site for a face to face. He wants me to quote against a guy that is...
23
13,811
I am perplexed. I am using an analog sensor output 0-10vdc into a micrologix 1400 analog in channel 0, there are no other analog inputs present...
3,718
