MLX 1400 analog in
markdobtech
May 2012
pa
I am perplexed. I am using an analog sensor output 0-10vdc into a micrologix 1400 analog in channel 0, there are no other analog inputs present. Using a scope at the analog input terminals, I can verify that the analog sensor is putting out a clean 0 - 10vdc as the sensor operates. However, looking at the I:0.4 contents in decimal format, the a/d conversion ranges about .2 - .4 vdc less than actual voltage at the terminal. Any ideas?
The 1400's analog inputs are 12-bit so I assume you have the scaling set up as 0-10V = 0-4095 counts?
You indicate the error as volts DC... are you reading the ATD value and converting it back to volts?
The 0.2-0.4V you mention, is it an offset over the entire range or do you see that difference at the top end?
Set for 4095
Yes on conversion to vdc
0 difference on low. Differential grows as vdc increases.
Thanks for the reply.
Hey Guys, I am struggling to read data from a "JUMO" make controller using modbus RTU with MLX1400. The communication between the devices has...
18
5,086
HELLO BOYS, I HAVE AN INTERROGANT, HOW CAN I MIGRATE A PROGRAM FROM A PLC MICROLOGIX 1500 TO A PLC 1400:beerchug:
1,632
Newbie question here, I have been trying to setup a Ethernet/IP network consisting of 3 AB Micrologix 1400 plc's, one Idec HG4G-CJT22MF-B OI, and...
3,334
I was talking to a customer on the phone. Sick kids so I couldn't get on site for a face to face. He wants me to quote against a guy that is...
23
13,802
I want to know the pin configuration to communicate AB MLX1400 with labview through channel 2 (9 pin connector) in modbus RTU slave mode. Also...
3,223
