AB MPL servo motor brake issue?
mike J
Oct 2013
King of Prussia,PA
I have a number of AB MPL servo motors driving material rolls through our machines. As of late, I am seeing a number of the brakes on these motors fail. Either they won't close, or conversely, they won't release. Has anyone else (If you use these motors) seen or heard about an unusually high failure rate on the brakes? Thanks.
Only problem that reared its head was that the brake release and brake set time were not set correctly in the axis properties so the MPL motor was driving through the brake when starting and the brake was being used to stop the motor - I now treat the brakes as holding brakes that should not be used on a spinning motor. In an emergency, of course, they are used.
What version of RSlogix are you using? what are you using to drive the MPL motors? Ultra 3000 or kinetix? Using SERCOS?
What is the difference between the Index+/- signals and the ABS signal shown in the pinout of the MPL-xxxxx-xx2xxx series servo motors ? Using...
1,606
If anyone has an MPL Servo, I'm looking for the flange dimension of the feedback connector. It will be either 25 or 28 MM. Thanks. I don't have...
1,486
Does anyone have any [successful] experience with an Allen-Bradley MPL-A320P servo motor and Ultra3000 drive? We have used the MPL-A320H motor...
5,185
How do you set up the PF 700S drive to commutate a MPL servo motor? THe PF700S manual describes how to enter the motor NPL data and the fact that...
4,483
Good Afternoon , I have a strange situation . We have a machine that has several Kinetix Servo drives and motors on. We had a maintenance...
2,985
