AB MPL Servo Motor Signals
Archie
May 2002
Orangeburg, SC
1,944
What is the difference between the Index+/- signals and the ABS signal shown in the pinout of the MPL-xxxxx-xx2xxx series servo motors ?
Using these motors with a Kinetix 300 servo drive and I do not see a corresponding signal for the ABS from the motor.
You have incremental encoder feedback on that motor (MPL-xxxxx-Hx2xAx)? I didn't think anyone did that anymore.
As far as I can tell there isn't anywhere to go with that signal on the K300.
Keith
But what is the ABS signal? I thought it was an Absolute position or zero, but the encoder already has an Index that serves that purpose.
Take a look at page 9 of this manual:
https://literature.rockwellautomation.com/idc/groups/literature/documents/rm/1398-rm007_-en-p.pdf
It looks like this may be a carry-over to support replacement of H-series motors used with drives that were designed to run H-series motors using the ABS signal. It is effectively an analog commutation signal that would allow a drive that can use it to immediately commutate a motor with incremental feedback without having to pass the encoder through the index pulse. it wouldn't be used with a K300 drive.
Keith
If anyone has an MPL Servo, I'm looking for the flange dimension of the feedback connector. It will be either 25 or 28 MM. Thanks. I don't have...
1,488
I have a number of AB MPL servo motors driving material rolls through our machines. As of late, I am seeing a number of the brakes on these...
3,164
Does anyone have any [successful] experience with an Allen-Bradley MPL-A320P servo motor and Ultra3000 drive? We have used the MPL-A320H motor...
5,187
How do you set up the PF 700S drive to commutate a MPL servo motor? THe PF700S manual describes how to enter the motor NPL data and the fact that...
4,483
Good Afternoon , I have a strange situation . We have a machine that has several Kinetix Servo drives and motors on. We had a maintenance...
2,986
