AB - Panelbuilder32 to new AB Plus_6 600 panelview error
leeviney
Dec 2014
Earth
Hello there,
Long time reader, first time poster.
To start with, I am not very familiar with the RS family of devices and software. I am GE man so dont be hating :). So i basically had a screen which broke, and it was replaced (all external to myself) now the screen has no program on it. I have researched and discovered that Panelbuilder32 is the program which the project is created in. The PC with panelbuilder and RS software is a stationary PC and cannot be moved. I have NO RS software on a laptop to connect locally to the screen. I have the screen IP set to 192.168.1.22, and the work PC set to 192.168.1.100. I can ping the screen from the work PC. when i download the program, i have used RSLinx as the connection to download. however i get an error message immediately after clicking download.
I believe i have 1 of 3 issues (this is where my heads at)
1) The screen is to updated, and the software is too old and i need to update something
2) the unrecognized device is RSLinx is the issue and i need to get that rectified
3) i do not have the local settings on the screen correct and i am just a rookie haha.
I have attached some screen shots, some more can be given.
any advice or assistance would be awesome.
cheers guys
The device you are trying to download to is a PanelView Plus, which uses FactoryTalk View Studio ME, rather than PanelBuilder32.
There appears to also be a PanelView Standard at 192.168.1.9 on your network. Could that be the one you intend to work on ?
My guess is that someone replaced a failed PanelView Standard with Standard with P but made an incorrect assumption about the necessary software.
Hi Ken,
You are correct, there is another screen at 192.168.1.9, however this is for a different component (it will eventually be replaced). So Ken, i have a few questions
1)so Factorytalk view ME studio is now used to program the Plus panelviews?
2) Can i use a program created in panelbuilder32 and open it in Factorytalk ME studio?
3) Can panelview standards still be purchased? or are they discontinued?
thanks heaps mate
Hello guys , im new at plc. i have a few questions hopefully someone can help me out. i extracted from an old panelview550 a pba file and...
1,433
Hi guys I'll appreciate for your support. I want to know if there is a way to change the text of a label depending of the numeric value of a tag...
1,084
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,629
A tech at a remote facility had a PV550 **** out (Err 690 DH+ hardware failed). He took it out and sent it to me, and going by the label on the...
1,257
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,597
