AB Panelview 1000 Screen - How to test if it is bad or not?
Jalopees
Mar 2009
Columbia, PA USA
I have a AB Panelview 1000 and the screen does not work. I had to replace the unit only after 4 years and was wondering how to test the screen to see if it is bad so I can just replace that or do I have some other problems. Does anyone have any ideas? Thank you.
What is the problem? What makes you think it is "bad"?
We can't help you diagnose it with the information you've given us...
The screen does not come on but I am able to connect with Panel Builder. Today I took the bulb out and place a flashlight against the inside case and I was able to see our application running on the screen, so does this mean it is the bulb? I was able to upload the program no problem. My unit is in a control environment. Any ideas. Thank you for your response.
I also had a 1000 that lost just the display. I didn't think it was the backlight, because I couldn't see with a flashlight. After reading this thread, I purchased the backlight. It is now working.
George
hi gay, the hmi works normally, suddenly the screen turns gray and no display appears. when I click on the screen I see that the cursor moves to...
1,397
Hey Guys, After a firmware upgrade and the addition of Viewpoint firmware on a panelview Plus 6, it will randomly promp the operator for a...
1,662
Hi I have a panelview 1000 (2711-T10C3) on a machine with an app that runs when the screen is powered up. The panelview is a touch screen, with...
4,648
Hi, This isn't specifically PLC related, but product related... We bought some replacement protective film covers for a Panelview Plus 1000...
2,474
Hi, guys, how r u? There are two panels on our production line. One is PanleView 1000 and another one is PanelView Plus 1500. Can we...
2,519
