AB Panelview Plus Username/Password
dabomb4097
Feb 2012
Chicago, IL
24
Hello,
I've set up a PanelView Plus 1500 project to have a login and logout button, with some hidden buttons that only come up when you log into that user account.
I set up the user under "System->Users and Groups->Users" in the project explorer then used visibility statement 'system\User = "myusername"' to show the special buttons when that user is logged in.
This works fine when I compile the runtime for an old PanelView 5.10 panel, but when I compile it to PanelView 8.0 for use on one of our newer panels I get an error when logging in that the user or password are not valid.
Did something change between PVP 5 and PVP 6+ that would make an identical project built for 5.10 work fine but not work when built for 8?
-db
I can't answer the question you asked - but just in case it helps, I typically use security codes for all login-related visibility. So I assign codes to each user and then the visibility expression becomes CurrentUserHasCode(x) where "x" is the security code in question. I've never had problems with that method.
99
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
63
Hello All! Ok, we got a Work cell from a Integrator that is sending saved scanning data from the PLC to HMI (Panel View Plus) when I look at this...
96
Hello everyone. This is more of an HMI issue. I have a new PanelView Plus 7 Series B. I am using the alarm list object to display the fault...
98
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
143
