AB PIC Driver Automatic Installation
Mar 2005
49
The project I am working on has an industrial computer. This computer is used to archive test results from the machine. The program running on this computer is a VB application and I am using Rslinx OEM, AB PIC(DH 485) driver to communicate to the PLC.
The problem I have is that the driver will not automatically install. I get a pop up when I restart the computer and I have to manually accept the drivers installation. That is fine for the moment but when this machine is at the costumers location he should not have to do anything for the archive to work.
Does anyone know a way around this....getting the driver to install without having to manual accept the installation?????
Hey Try this it might work
In Win XP
Right Click on My Computer Go to properties
click on the Hardware Tab
Click on Driver Signing and chose the first option Ignore.
Let me knoew if it works Good Luck
Yasir
Im getting trouble with my plc using 1747 pic connection, i found this solution: http://www.plctalk.net/qanda/archive/index.php/t-63919.html, but...
2,267
Hello everyone, I received a Fatal error message when added driver 1747-PIC, after that I closed that window and driver was added normally, but...
2,155
I've been searching and have tried everything. I can currently connect to a SLC 5/03 using RS-232; however, I want to test the RS-485 connection...
3,814
Hello, I am running Windows XP SP2 and Rslinx does not have the 1747 PIC AIC+ driver available. Not showing up on driver list/selections. Is...
4,083
Let me start off by saying I know I need to get a 1747-UIC, but I can't get one in for a couple days and I'm working on something time sensitive...
9,521
