Fatal error - driver 1747-PIC
Jun 2016
Macaé - RJ
Hello everyone,
I received a Fatal error message when added driver 1747-PIC, after that I closed that window and driver was added normally, but the driver is stopped and buttons "start-up","start" and "stop" are grey.
(Before add the drivers I have unchecked the box "Always run as service mode" at RS Linx Classic Launch Control)
Appreciate a help...
Tks for the prompt reply...
Linx Version: Classic 2.58.00
Windows XP Professional Version 5.1.2600 SP3 Build 2600
I need to connect with PLC 1764 - LRP
As I saw in program, the driver configured was AB_PIC-1
One possible problem, see link
http://www.plctalk.net/qanda/showthread.php?t=63919&highlight=sp3+patch
Another is, does your PC have a real serial port? That driver will not work without one.
You can also use the "Communications Toggle Push Button" to set channel 0 to its default (DF1 protocol, then use the DF1 driver with a null-modem cable). see pdf below page 4-1 and 4-2 for more info
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1764-um001_-en-p.pdf
HI EVERYONE I am having problem when installing 1747-PIC and I always get this message as title of this thread.Laptop with win xp SP3 and rslinx...
13,060
Hi All, I've been pulling my hair out trying to fix this for a few days and need some advice. I have V19.01, v20.05, V21, V24, V30, V31, V32...
413
Hello, this is my first post after being a long time creeper on this forum. I am experiencing a fatal error any time I attempt to print to PDF...
390
Howdy Everyone, So recently I started getting a fatal error anytime I open the monitor in a specific program in logix designer error 0x800420b1...
1,134
Hi all, I am getting a Fatal Error of 0xc0000005(-1073741819) While installing V21.03 on Computer(please refer to the attachment ) please help
1,785
