AB pico gfx question
ninholeus
Feb 2008
Toronto
I just purchased a pico gfx
--1760-LDFA ser.A rev.D
--1760-IA12XOW41 ser.A rev.A
--1760-DU ser.A rev.B
When I try to connect to the plc using picosoft 6.10 pro I get the message the connected device does not belong to the device series expected. I think that they supplied me with the wrong series control for the software. Can any one confirm this or help me in any way.
It seems like your Pico may be using the wrong COM port. Also, did you make the Language Selection first?
Establishes a connection from the PC to the connected device via the selected COM interface.
Note in the event that connection establishment fails:
Ensure that no other application is currently running on the PC interface you have selected.
Check whether the connected device is ready for connection. For example, a Pico Controller requires you to make a language selection via the cursor buttons the first time it is commissioned. Only then can a connection be made!
The Com Port number must be the one that your PC is set up to use. Other programs or drivers must not be using the COM port at the same time.
You may need to upgrade to PicoSoft Pro v6.22 the later pico gfx won't conmmunicate with the 6.10 software.
Theres a Faq on the Pico section of the Rockwell site.
They provided me with the picosoft pro 6.22 software today and that gave me the option of chooseing ser A or ser B devices. Now to take over the world!
No . It is a new software version not just a patch. They did give to me But I am not shur if it a free upgrade for all.
I am having touble reseting the QV (acutal value) on the standard counter with AB GFX pico control. :banghead: I would like to reset the counter...
1,861
Hello all, I have a simple (I thought) application in which I need to count pulses for an RPM measurement. I have an input wired to a counter in...
2,094
I have never used the Pico GFX, but I have been looking at it for a somewhat simple application. AB is hiding the programming manual somewhere on...
2,801
My first question here, and life hangs in the balance! lol. Here's what I got: I need to be able to swap associations for the PICO's single...
3,926
I Have An Application Where I Am Applying Various Colors To A Moving Block Of Product. Input 1 Recieves A Pulse From A Prox Switch. I Need To...
1,353
