Pico Gfx Issues With Counters
HITECHKC
Nov 2007
MEMPHIS, TN.
I Have An Application Where I Am Applying Various Colors To A Moving Block Of Product. Input 1 Recieves A Pulse From A Prox Switch. I Need To Activate Output 1 At 2 Pulses, Output 2 At 4, Output 3 At 6, Output 4 At 8 Pulses, And Reset At 9 To Start Over.
Having Trouble Reseting The System. Any Guidance Would Be Most Helpful And Appreciated. I Know I Need To Use The Marker Words But Just Dont Have A Grasp Of The Heirarchy. Previous Plc Experiance Is On Honeywell Hc-900 Systems Whole Different Animal) Thanks K.c.
Well, I am not a Pico expert, but looking at the Pico GFX, I would use Input 1 to trigger a Counter. You should have 32 counters, C01 to C32, so you might use Counter C01 for this. Then add the following additional rungs:
If C01 = 2, then turn on Ouput 1 (Use the Comparator instruction CP01 and Set Output 1).
If C01 = 4, then turn on Ouput 2 (Use the Comparator instruction CP02 and Set Output 2).
If C01 = 6, then turn on Ouput 3 (Use the Comparator instruction CP03 and Set Output 3).
If C01 = 8, then turn on Ouput 4 (Use the Comparator instruction CP04 and Set Output 4).
If C01 = 9, then Unlatch all outputs (Use Comparator instruction CP05 and the Reset function on Outputs 1 to 4).
I am having touble reseting the QV (acutal value) on the standard counter with AB GFX pico control. :banghead: I would like to reset the counter...
1,860
Hello all, I have a simple (I thought) application in which I need to count pulses for an RPM measurement. I have an input wired to a counter in...
2,093
I have never used the Pico GFX, but I have been looking at it for a somewhat simple application. AB is hiding the programming manual somewhere on...
2,799
I just purchased a pico gfx --1760-LDFA ser.A rev.D --1760-IA12XOW41 ser.A rev.A --1760-DU ser.A rev.B When I try to connect to...
3,014
My first question here, and life hangs in the balance! lol. Here's what I got: I need to be able to swap associations for the PICO's single...
3,925
