PICO GFX Analog Output problem. Ahhh!
toygasm4u
Nov 2007
Lexington, Ky
My first question here, and life hangs in the balance! lol. Here's what I got:
I need to be able to swap associations for the PICO's single analog output. I'm setting up a hand off auto mode for this output. In auto mode, I'm sending a scaled value to the output via a Marker Double Word from an Arithmetic Function block. This works great by itself. Now, in hand mode, I want the same analog output to respond to a different Marker Double Word from a different AR block. I can't seem to get this thing to toggle back and forth in the simulation mode. I tried a jump, and that didn't work.
How would you guys do this?
A jump is not needed. Switching the input to the analog output is needed.
| AUTO MODE +-------------------+ ANALOG OUT |
|---| |---------| SCALE MARKER |-----+-----( )-----|
| | DOUBLE WORD #1 | | |
| | FOR ANALOG OUTPUT | | |
| MANUAL MODE +-------------------+ | |
|---| |---------| SCALE MARKER |-----+ |
| | DOUBLE WORD #2 | |
I am having touble reseting the QV (acutal value) on the standard counter with AB GFX pico control. :banghead: I would like to reset the counter...
1,860
Hello all, I have a simple (I thought) application in which I need to count pulses for an RPM measurement. I have an input wired to a counter in...
2,094
I have never used the Pico GFX, but I have been looking at it for a somewhat simple application. AB is hiding the programming manual somewhere on...
2,801
I just purchased a pico gfx --1760-LDFA ser.A rev.D --1760-IA12XOW41 ser.A rev.A --1760-DU ser.A rev.B When I try to connect to...
3,016
I Have An Application Where I Am Applying Various Colors To A Moving Block Of Product. Input 1 Recieves A Pulse From A Prox Switch. I Need To...
1,353
