AB PLC-5?40E Can't communicate to Simatic PG Com.port 1
neziu
Aug 2006
Malaysia
Hi to All AB User/s,
I want to learn basic programming in AB plc but the problem is my Company's Siemens Field PG (6ES7710-3DA12-1BE1) cannot communicate in our old factory control AB PLC-5 (1785-L40E/E Rev C01 Series E F/W Rev A).
I already fabricate cable based on the manual/s that I downloaded thru AB website. Cable pin-out for 1784-CP10 and 1784-CP11. I also configure the Switch 1 and Switch 2 to address node 1 and RS232C communication, respectively.
When I try to communicate using RSLinx the PLC-5/40E was detected but with faulty as status. And when I download the program in the PLC using RS5Logix ver 6.2 the timeout was activated because the PLC cannot be detect by the Simatic PG.
Please shed some light for me.
Thanks,
neziu....
Hello Everyone, I am reaching out to this knowledgeable community with a peculiar problem I've been experiencing with a PLC 5/40E. This issue has...
2,314
Have a PLC5/40E that has a battery installed and a working battery warning light that is off with the battery plugged in. There is no memory...
2,752
Please help me! I need to perform the firmware update for PLC 5 1785-L20E / 1785-L40E and 1785-L80E, but I do not find these firmware to download...
2,419
I am trying to connect a PLC-5/40E to Ethernet via a 1761-NET-ENI. After reading several other forums and technical sheets I have connected the...
5,134
Hi, We have a PLC 5/40E (1785-L40E/F) which is not working. We do have others like PLC 5/40, 5/60 and a 5/80 in our stock. I like to know if I...
1,946
