AB PLC Point I/O
Gio926
Mar 2018
USA
Hello all,
I have a FANUC robot running on a compactlogix PLC. All the physical IO is either going to the robot or through distributed IO modules with M12 connectors. I want to install an IO module inside the controller cabinet for a terminal style IO.
I came across the AB Point IO module 1734-AENT (for Ethernet/IP) which allows me to add modules as needed. Going through their selection guide, my options for input and output allow me to choose between sinking/sourcing. I believe the standard is a sourcing output module and a sinking input module but I want to make sure I don't mess anything up. Any advice on which to choose or where to get the info on what I should choose?
Thank you
I provide systems for a customer that gets equipment from his parent company in Japan - sinking outputs and sourcing inputs. So they're still out there. PIA when trying to tie in the safety circuits that are required here.
I have a bunch of tags in Historian/VantagePoint that off by one decimal point. I looked into the HMI displaying the same number, and the HMI is...
117
I have a robot cell controlled via PLC. I want to use an output from the PLC, based on whatever part number the cell is processing, to open a...
902
Hi, can anybody tell that how can we move floating point data from one Regiter to another register in Fatek PLC.?
1,553
Hello guys, i am taking a value from load cell module, i have to scale it so i want to divide it by 100 but the Wlsoft doesn't give me the...
4,323
Hi; I have been the user of Allen Bradley PLCs but now working on programing of Fatek FBs PLCs. I want to know how do I create a floating point...
2,121
