AB PLC with OPC server using Modbus TCP
mbreddy
Nov 2014
bangalore
22
I have some ladder application which controls motor drive.Right now i have connected PLC with KepexServex with ethernet tcp/ip.Now i have a question.I wanted to change the communication btw PLC to Kepex to Modbus RTU.I need to understand what kind of changes required in PLC coding part to make the communication works.
Assume that I am using O0.1 pin from PLC to start/stop motor. I can configure this bit in Kepex as O0:0/0. I dont know how to expose this bit in kepexserver when communication is modbus.
Please guide me.
Hello, im new to this PLC World, im a student currently in an internship, my boss wanted to know if i knew if there is any way to extract data...
1,945
Hi All, I had a question regarding Kepware. I was able to pull in data from my PLC tags along with the tags coming from the third party OPC...
1,102
Hi All, I am new to OPC UA and I am trying to figure out the best approach to make this happen. I feel like I missing something simple here. So...
3,727
Hello, I am looking for help writing to PLC tags from Excel. I am using Factory Talk Gateway as an OPC server and Excel VBA to write out to an...
3,108
Hi, I'm working with a Citect OPC DA server and an Allen Bradley ControlLogix L71 PLC. I have set up my boards, ports, and I/O device. When I...
3,288
