AB Power Flex 40 speed control
chintankAne
Apr 2014
Surat
80
Hi i am working on project in which i am using AB compactLogix and Powerflex 40 for AC motor. i need to control speed of motor.
But i need to use use EtherNet Ip for my Power flex40.
for that i go through
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/motion-um003_-en-p.pdf
and
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1769-um021_-en-p.pdf
(CH-11)
But i got only how to configure motion on eathernet. But i need help in my Ladder programing.
so please suggest me any manual or vedio link.
I’m using a PF 4M with 4-20 mA speed reference. Keypad start stop. The drive will go up to speed and allow me to adjust speed with my 4-20...
1,163
We have conveyors controlled by Power Flex 525 and they are Ethernet connected via stratix switch with PLC 5000. We have a fault Over Speed on one...
5,671
Hello All, Please one the powerflex 755 Drives looses itds speed reference anytime power-cycle the drive. Parameter 545 goes to default and must...
2,729
What could cause a drive to output above set point speed reference while in flux vector and speed control? Drive in question is attached to a...
5,050
Dear guys, Our motor is running with 50 hz.but I want to run it with 45 hz when I select preset.I read manual but confusion is not...
19
5,583
