AB power flex dc product profile problem
sgates
May 2007
Utah
17
I am working on a project whitch will use 4 Power Flex DC Drives to turn a big wheel. I am using rslogix 5000 with a 1756-L61S processsor. When I downloaded the Product profile for the drives, every time I try and change the drive setting I get a fatel error and my laptop shuts down. This not only happens with rslogix 5000, but also with drive exploror. Please for give the spelling, it sucks I know
Thanks Steve
I run a similar set up without any issues. My first instinct is to tell you to uninstall and then re install the software and see if the problem persists. I don't think it's anything to do with your hardware combination, but I've been wrong before.
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
137
Hi all. Would anyone happen to have the Modbus register datasheet for the Honeywell/EnergyICT EIMFlex Modular Meter v1.11 We've 40 of these that...
73
I have an issue with Power Flex 525 during running processing, the VFD stopped suddenly while the PLC and VFD connection ok, VFD does not have any...
138
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
205
i have a flashing yellow sts light. "Stop Asserted" message on one of my PF 753"s, but no bits set in parameter 961. The safety circuit tests...
215
