AB Rslogix5000 Function Block Programming
In general in can make complex things much easier to code and the function block code is easier to read and many times you can get everything you need in one area of the screen and avoid a lot of scrolling up and down to read the code.
There are some advanced instructions in function block that a lot of people like to use over the ladder equivalent one such example is using the function block PIDE instruction over the ladder PID instruction as it functions much better and has better control and more features.
Function Block programming is, IMO, best to display flow of code if you have a good library of process blocks (like Valves, motors, etc...).
This then allows you to see the inputs leading to the control block and the respective outputs.
Edit: in other words, it reduces the cross referencing a whole lot.
Hello I'm trying to use function blocks to scale engineering units to W.C. reading. but I don't see the option to create the function block is...
1,062
I'm modifying my first function block program in RSLogix (I've only done ladder and ST on the AB PLCs before). The existing program looks like a...
1,788
Anyone know of an easy way to program a FIFO in function block for RSLOGIX500. There appears to be no instruction for this. I'm sure I can put...
2,813
I'm making a quick foray into using a FBD routine in order to use the SCL instruction and I found a couple things I could not find an explanation...
6,750
hi I am unable to view function block diagram i.e. boolean functions I've installed version v13.04.00 The installed components are Ladder...
3,869
