AB T47 Programming Terminal
Tn 20098
what does "TN" stand for? (tech note?)
how do i go about getting this? if this is where i get the "config" program for the T47?
do i have to join something?
Like Control_Conn said, it's only available from Rockwell Automation Tech Support. If you have a support contract, you can give them a call and have it sent to you. If you don't have a support contract, drop me a line through my Forum profile and I'll send it to you.
I just put the setup.com file in the allen bradley download section.
Boot to a Dos disk then run the setup.com
My T47 runs disk 33 for hard drive selection. 40 meg hard drive.
I`am don`t have a support contract, but should like to restore terminal T47 with bad battery. Can You help me with "config" program for the T47?
The RA Knowledgebase Answer ID # 20098 is definitely the downloadable BIOS configuration diskette image for the 1784-T47 programming terminal.
That document comes up when you do a "phrase" search, an "Answer ID" search, but not if you do a "Previous TN#" search.
Or follow this direct link: Answer ID# 20098
KEN,
I have the same problem, could you send me the file ?
thanks
Hi. After hours of online searching I could not find the setup program for the T47 programing terminal and neither for DataGeneral Walkabout SX. I know that this thread is pretty old but looks like here is the closest option I got. If anyone here still have the setup diskette image or the executable file please contact me through my forum profile. Thanks!!!
A few months ago, I had 2 T47s with PLC2 soft, but I did not have a need to use them since I was able to run what I need from XP machine.
(y)
Here's a blast from the past. Does anybody know how to echo (or redirect) the video output to an external monitor? I plugged a monitor into the...
1,584
Hello, I´m using an old T47 for an PLC2 converting. Somebody has installed MS-Dos Version 6.22 on this. I want to use the mode2 instruction to...
1,260
I have an Allen Bradley T47 Laptop that I use to communicate with an Allen Bradley PLC5. I need a copy of the ICOM software and or the 6200...
2,222
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
41
238
