AB translate SLC to RS5000 opens Studio5000
gofastnow
Jan 2017
USA
Noobie here needs help.
I am converting an SLC 5/04 to compactlogix. I have run the Translate PLC-5/SLC 2.0 program within RS5000 and it seems to convert ok------except when I open the file ACD file, the AB environment automatically changes from RS5000 to the Studio5000 environment. I really need to keep it at versioin 19. Anybody run into this before?
Thanks in advance.
Ensure that the processor your using will run with version 19. I believe 1756's (ControlLogix) before L71 will run 19 or 20, not sure about 1769's (CompactLogix). Then in your RSLogix/Studio change the controller to the one you are using with the 19 software version (Right click on controller in the tree -> properties, click change controller out besides type in the popup). The RSLogix system will reconfigure and load the proper version of RSLogix with the program at the version you want.
Noobie here needs help. I am converting an SLC 5/04 to compactlogix. I have run the Translate PLC-5/SLC 2.0 program within RS5000 and it seems to...
2,014
Hello. im try migrate my program from SLC to Rslogix 5000, but i have some detail about PID convertion. The parameters for PID are not all same...
2,183
I need to Translate a Siemens S7 project into Delta PLC. I am responsible for Electrical so I will not care about software. Delta does have PLCs...
1,191
Can some one transfer this to ladder logic please L #InR T #PuntoX L #Punto2 L #Punto1 -R T...
1,986
Helo guys, New to siemens and STL . Can some one translate this ladder logic. In simatic manager when I change language it doesnt work. A...
2,277
