Your original P/N is for a polarized retroreflective 90-130VAC wit h SPDT relay output.
I was confused when the discussion turned to surge suppression and output transient control.
You just unluckily got sold a bad batch of photocells...something that has never happened to me with Banner products, but has happened with some other lesser brands.
If the photocells only drive input points on a PLC card and nothing else, there is no way they should have welded the 5 amp relay contacts unless there was some intermittent short or an electrical condition that overloaded the internal relays, perhaps during checkout, and was later corrected. Isn't the input impedence of a typical PLC input card something like 10k ohms? Not nearly enough current to weld a 5amp relay closed. In that type of application, the relay photocells should last years and years. Solid state eyes will last virtually forever in that application. Most modern solid state eyes will work with most modern AC input cards without "false triggering". Avoiding that problem might be the reason a relay type eye was selected.
The new part number is also a relay type, but one of the newest Banner lines. Those little QS series eyes are fantastic in my limited experience. You will like them much better anyway.
Paul
