ABB IRC5 and Profibus DP
Branislav
Jan 2013
Beograd
Hello to all. Could you please help me with this one. We would like to use command WRREC in order to send some data from PLC to IRC controller(slave) but I'm not sure which starting address to use for writing. Could you please help me. Thanks.
We are using ABB dsqc 667 profibus fieldbus slave adapter on side of IRC5 controller that supports DP Ver.1 non-cyclic transmission. IRC5 is limited to 64 bytes input size for profibus communication.
Hi
Maybe I not picking up on your question right but will the address be what you set up in the Irc controller in the field bus tab. I have only setup devicenet to a Irc from scratch but I worked on a few that had been set up on profibus before i worked on them. If you press Abb, then system I think ,then I/o, and select a group input or a single Input and map it to you field bus address.
I am only doing this From memory so it may be a little out but not much.
I hope I have understood your question.
Donnchadh
Hey guys, I am having some trouble with one of our profibus node on the network. We have an S7317 PLC (DP MASTER) with 5 Siemens slaves and 2...
10,737
We run multiple products on our machines, which means we have multiple robot programs that we swap to, due to the points for the robots having to...
1,925
Very general question here. Are there any general function blocks/Add on profiles for ABB IRC5 when connected over EIP? If not, why not? I've...
3,478
hello all, I am trying to program a keyence vision system to recognize how a part is oriented and then tell the robot so that the robot can pick...
3,489
Hello I'm trying to Connect ABB IRC5 controller using profinet to Siemens S7-1200 PLC The PLC is the master and IRC5 is the salve. The IRC5 has 2...
8,363
