ABB robot power off
khewes
May 2016
New Hampshire
123
Hello all,
quick question
Does turning the power to the robot controller for an ABB IRC5 cause it to crash?
its in home position right now, and I want to get into the controller to wire some outputs.. but im not sure that if i switch the power off the robot will stay at home or fall.
should it stay home or will it fall?
thanks,
kris
As always, it helps to know which model is being discussed. That said, the one ABB robot I worked on, built 25+ years ago, had brakes on each axis which engaged after a period of no movement or E-stop or power off.
Hello all,
quick question
thanks,
kris
I just attended a ABB IRC5 class the first week of December. Doug is correct, the robot has brakes that engage whenever the enable is not made. It also has resolvers instead of an encoder so if the battery backup for the resolver "memory" are good then it will "remember" where it is parked. If the battery is not good then all bets are off. The battery is at the base of the robot and is wrapped in blue shrink tubing.
Very general question here. Are there any general function blocks/Add on profiles for ABB IRC5 when connected over EIP? If not, why not? I've...
3,473
On all of our lines that have Fanuc robots, we have the cabinet e-stop and pendant e-stop mapped to seperate DOs for messages purposes. We also...
2,503
Hello Everyone, I want to send a string from AB PLC to ABB robot control. I can send integers from PLC to abb robot using group input but not...
2,367
Has anyone tried communicating ABB robots IRB4600 or IRB2600 with HMI.
1,288
hi i try to do a simple program displacement program using PDispOn PROC move_up_back() PDispOn *, tool1; MoveL *, v500, z10, tool1; PDispOff...
2,064
