ABCLX & SCADA Tag Problem
acurabot
Jun 2017
Australia
I have an issue with COMS with one of my tags. I can't get online to the PLC if I have this one family of tags present. Without it, I can. I'm using CitectSCADA 7.2 SP4 and a ControlLogix L61 PLC on RSLogix v20.04.
Tag in AOI Parameter: CV01_E300.Available
Tag in CitectSCADA: CV01_E300_Available
Address in CitectSCADA: CV01_E300.Available
The errors I get on ABCLX log are (in order):
- Mismatched Message [EIP] (x4, x3 or x2)
- SendUnitData response with CIP error causes session failure [EIP]
- Time Out. Channel Not Initialized [DCB]
- Session Failed [DCB]
I have tried things ie.
1. Sorting variables DBF by IODevice and Data Type
2. Packing, resetting OID
3. ABCLX troubleshooting: http://proscada.ru/ctkbase.en/articles/q4009.html
4. Creating a new variable DBF
Any ideas as to what it may be?
Any help would be most appreciated.
I have just found that in my AOI, the external access was "None". By changing this to "Read/Write", it has fixed my comms issue. šŸ™ƒ
Good afternoon All, I have a Citect System that has been installed for roughly 1.5 years, It connects to 11 remote sites using MDS Inet...
2,225
Hi, just starting to learn citect Scada, and im trying to connect it to the control logix, i have followed all the instructions in the "help"...
3,909
I am trying to talk to a Control Logix PLC via Citect SCADA. This is the first project I am doing with CitectSCADA and I am not sure what is...
4,728
Hi I am having comms issues between Citect 8.2 and Compact Guardlogix. 2023-07-14 07:50:54.788 +10:00 [ERROR] [CORE ] [0x114c] [IOServer...
885
I've use windows XP and ABCLX driver v3.0.4 for citect 6.1 cannot run (display: your driver is not initialized). I wanna ask if ini this forum...
1,652
