About Exter HMIs
Shohadawy
Aug 2008
Egypt
66
I'm going to make a project in which I'll use an Exter T100 Op panel in connection with an Omron PLC , Model: CQM1H, or CPM1.
Can I connect the Exter with the CQM1H and CPM1? Which protocol should I use for the two models... Hostlink or Omron FINS or what protocol I should use?
Hi, I'm currently having an issue with a Beijer T70 HMI. We have 2 HMIs talking to a Yaskawa motion controller via modbus over ethernet. The...
582
Spent the best part of the day trying to figure a problem with the Beijer Exter series no protocol mode. I got it sussed and so thought I would...
3,316
Does the Beijer Exter support PID blocks using the CLX (compactlogix)driver & using the L5K import . CLX Ver 4.15
1,831
Is there a way to wrap a message object text to second line if it does not fit the object size? EXTER T70
1,460
I'm using an "Exter T100" touch operator panel and the configuration software "Information Designer". I'm developing an application in which the...
1,952
