apology: I'm pretty sure that what follows is going to take us further away from the question that the original poster had in mind ... still – a stone has been turned that I think needs a little more clarification for safety reasons ...
Greetings Gil47 ...
let me start out by saying that I wholeheartedly agree with you on the TOF vs. TON points that you made ... but for the benefit of any "beginners" (and even some "beyond beginner" readers) who might pass this way in the future, I think we need to go just one step further with the TOF vs. TON discussion ...
the only point that I'd like to add is that it's entirely possible use EITHER of these two "timer" instructions in a program and have the system function PERFECTLY in normal day-to-day operation, BUT then later to experience something "bad" when the system goes through some type of unforeseen startup situation – simply because the "wrong" timer was applied ...
one specific situation that I've run across in the past is covered in the discussion for Figure A in my Email Quiz #121 - "Surprises at Go-To-Run" ... if anyone's interested, it's available free from a link near the bottom of the Sample Lessons page of my website ... (the answers to the quizzes are also available as separate free downloads) ...
the point I'd like to make is summed up this way in the quiz:
The basic idea is that PLC programs often work PERFECTLY in normal day-to-day operations – but then may give surprising (and embarrassing – or even DANGEROUS) results when the system is restarted after a shutdown; or experiences a “flicker” in the plant’s power supply; or is switched between the Program Mode and Run Mode; and so on.
so in closing, once again, I fully agree with the advice posted by Gil47:
read the help files on the TOF until you fully understand its operation
I just wanted to add that beyond just reading and understanding the help files, you should ALWAYS check the operation of any programs that you write (and/or work with) not only
(a) in their normal day-to-day operations – but also
(b) for how the systems will function in various situations when they first enter the Run mode ...
the differences between TOF and TON timers is a commonly overlooked area where one size definitely does NOT "fit all" ...
