jtashaffer Member Join Date Aug 2009 Location KY Posts 415 Jun 18, 2014 #1 I want to use a 1 minute off delay timer. Can some show a programming example. It is for a l32e compact plc
jtashaffer Member OP Join Date Aug 2009 Location KY Posts 415 Jun 18, 2014 #2 I want to shut the output off after a minute
FactoryTalktotheHand Member F Join Date Nov 2013 Location Michigan Posts 532 Jun 18, 2014 #3 Use the TOF Instruction. Set it for 60000 (60,000 milliseconds). The .DN bit will be on/high/1 as soon as the rung the timer is on goes false and will remain until the timer times out.
jtashaffer Member OP Join Date Aug 2009 Location KY Posts 415 Jun 18, 2014 #4 Thanks for the help. I was having a brain **** at work. I ended up using a TON timer timing
