accessing object property using script wincc flexible 2008
RTA
Apr 2010
Bangalore
Hi all,
I am trying to change the property of an object in the current screen. Changing the color of the object works fine but BLINKING property is not accessible. Any help?
Dim objCircle
Set objCircle = hmiruntime.Screen("Screen_1").ScreenItems("Circle")
objCircle.BackColor = vbGreen Works fine
objCircle.Blink = vbGreen Does not work
Is there a way to access properties of vba-exposed objects on other screens? For example, if I click a button on screen "MAIN", does SE allow us...
3,618
Hi All, I'm working with 12 or so global objects I created, that are temperature displays (basic vertical gauge). Each has several parameters...
2,859
169
For the past few day, I have had problems accessing the Rockwell Knowledgebase. When I try to access it (and I do have a TechConnect Support...
409
Hi, Small issue i've really been beating myself up over today. I've been working with Panelview panels for years. Currently working on an older...
591
