Peter Nachtwey
I don't understand why there is a problem. The amplifier should be able to convert voltage to current in a dumb mode without an encoder input. Then the M02AE needs to run in torque mode where the control output is proportional to the current for the required acceleration instead of the required speed. The problem with this method is that if power goes out there is nothing to stop the motor and load unless there is an external brake.
