Active X Control In Scada
AJMUL
Dec 2006
DUBAI
57
Is there can I get set of ACTIVEX controls and SYMBOL Factory
(set of symbols)..............
If possible please provide the link
siemens(cp343-1)-wonderware(9.5) communication
hi all
As I am need of siemens and wonderware communication details..
I tried lot of times i couldnot able to communicate.
I refered some materials from wonderware then i couldnot
understand lot of terms.
Below I have provide the details....if somebody have to aware
of this issue...please help me
SCADA SOFTWARE:WONDERWARE'S INTOUCH(VERSION 9.5)
SIEMENS HARDWARES:CPU 315-2DP(S7-300 TYPE)
ETHERNET MODULE(CP 343-1)
COMMUNICATION TYPE:ETHERNET(DIRECT CABLE)
PROTOCOL:SI DIRECT DA SERVER(got it from device integration CD)
note:I can able to ping the plc system.
http://www.softwaretoolbox.com/Prod_Services/HMIAddIns/Wonderware/wonderware.html
Well, It doesn't mean much!
It only means that there is a good "physical" connection for the PC and PLC network and that IPs are set properly.
I don't about the OPC server you mentioned, So I can't provide any info about this, But we can troubleshoot the problem together ..
First of all, How do you know that the OPC server is communicating with the PLC correctly or not?
Is there any tool to monitor PLC registers in this OPC server (I want to remove the SCADA software from our test)
What are you asking for? You will probably get better responses if you separate your topic posts that have nothing to do with each other.
AJMUL said:
hi all
I want to browse web Page through Secada ft view 9.0 using active x control Microsoft web browser please guide me
1,136
Hi, I want to take a drop down box with 100 items , for which I am trying to use active x control combo box for FTV SE , please guide me how to...
1,300
Hello. I need to log data from registers on a CSV file to a USB stick. I have a panelview plus 700 CE, with 5.1 firmware. The catalog number...
2,775
I am running RSView32 7.40 and attempting to open a .pdf document using the Adobe pdf Reader Active X control. How do I access specific .pdf files...
1,910
Has anyone every used the Adodc_1 data control to connect to a database? I am trying and it keeps giving me compile errors. "Fatal ERROR: screen...
2,715
