Factory talk view studio -- Active X control question
snakes79
Nov 2015
Illinois
17
Hello. I need to log data from registers on a CSV file to a USB stick.
I have a panelview plus 700 CE, with 5.1 firmware. The catalog number is: 2711P-T7C4D7. There is an Active X control: ME Datastore Plus, but I am having trouble with the path to write the CSV file. I am also unaware if the Active X controls work on these older panelviews.
I have a micrologix PLC (1400) for my test PLC.
Any help would be great!
JF
The activeX work, but you need to use/install the older version of those activeX controls (in FTView Studio).
If you are using version FTView Studio 6 or higher, then the activeX installed there won't work on the 5.1 runtime
There was a thread about this just recently, somewhere...
107
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
326
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
290
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
593
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
369
