Actuators & Positioner
eng_muslim
Jul 2004
cairo
49
Plz can anyone give me simple introduction about actuators and positioners i know none about them and i tries to search the net about this subject but i find nothing
write to me or give me the sites which will help me
thnx in advance
ahmed marmoush
Hi !
The positioner is used to control the movement of the actuator. Suppose you are having a Control Valve having pneumatic actuator to control the downstream pressure of a pipe. So you have to control the valve. You can give 4-20 ma signal to the positioner. Positioner would convert the same to pneumatic signal and give it to actuator. Actuator would move the spindle of the valve. i.e it would rotate the valve (if rotary valve) or lift the valve (linear valve).
Obvious there are different kind of positioners also. only electric positioner, electro-pneumatic positioner, pneumatic position, electro hydraulic positioner and so on.
you can use www.google.com to search about it. write "positioner" and you will get many.....
thnx
it was very helpfull guys and so many thanx,i need someone tell me wht exactly good in ABB automation & drives products so i can start to learn about.
thnx in advance
Hello world! The company I started working for has these valves that they ordered years ago as spares. now we have to add couple valves on...
199
Hello, I'm fairly new to PLCs and only know the very basics of how it works as well as some programming. My goal right now is to extend and...
6,245
We will be constructing a gripper for a robot. The gripper will have the ability to extend itself in length and width direction. For this...
1,728
Hello guys, I have to send some Digital output from DCS ( ADV869 ) to control a valve open / close. The valve actuator diagram is Emerson M2cp...
1,530
Hi ! , not sure if anyone here knows how to calculate this.. but just in case ; I will instal a cluster of 20 valves and have to calculate the...
4,694
