AD Question
Steve Meisel
Jun 2002
NC
77
I am working on my first Automation Direct project and I have a couple of questions. The plc is a Siemens TI435 and I am adding a analog module to do some measuring of the depth of a metal tube being pressed into a part.
1. Does the processor have any retentive memory? I want to store some numbers from the HMI for the tube depth limits. I would like them to be retained in case of a power failure. Currently I have to hook up the pc to change the limits using a constant.
2. Is there an easier way to clear or zero 4 sequencial V registers than: load 0 out V1505, load 0 out V1506, load 0 out V1507, load 0 out V1510
Thanks,
Steve
Assuming that a TI435 is the same as a DL-430, then the answers are yes, and yes... :D
To select which ranges are retentive, you use the "PLC" pulldown menu, then click "Setup"--->"Retentive Ranges". You're ARE using DirectSOFT, right?
As far as clearing multiple registers, check out the "FILL" instruction. You specify the number of registers to fill, the starting location, and the value to fill them with.
See page 141 in Chapter 5 of the user manual which can be downloaded HERE... đź“š
Now that you've discovered A-D, I have a feeling this 'first' A-D project won't be your last!... :D
beerchug
-Eric
Thanks.
Thanks Eric for the reply.
The TI435 is the same as a DL-430 and yes I am using DirectSOFT32.
Thanks again.
Steve
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
169
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
71
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
93
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
92
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
