Adapter for U2DHP to blue hose ?
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,342
I am guessing that for DH+ networks it is more futureproof to purchase a U2DHP adapter than a PKTX card, given that PKTX is for PCI and not PCIexpress.
So I would prefer to purchase U2DHP rather than PKTX.
Problem is that the U2DHP only has the 8-pin mini-DIN connector. You cannot directly connect a blue hose to the U2DHP.
Anyone make an adapter for this purpose ?
It would need to have an 8-pin mini-DIN female port on one side, and either terminals or a male 3-pin Phoenix connector on the other side.
I guess we could make it ourselves, but if we can just buy it somewhere it would be better.
Thanks. Hmmm... the closest candidate is this one
https://www.plccable.com/allen-bradley-1784-u2dhp-plc5-1784-pcm6-1784-pcm5-phoenix-adapter-for-dh/
But it looks like it has a female phoenix connector. I would prefer it to be a male connector so that the blue hose cable which already has a female connector can be directly plugged into the new U2DHP with adapter.
I guess my customer could just parallel connect the wires in the female connector, but that is not neat and proper enough to my taste, if it could be avoided.
Correct, its made to plug into a 5/04 if the other connections are being used
Send me a email and I can send you the pinout, then you can just buy the cable over there, no reason to spend the money on shipping... it would cost twice the cable price for the shipping, now if you were buying a U2DHP and the complete set the shipping would be worth it
Mark
[email protected]
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
178
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
243
So I just discovered that Rockwell has a tool for taking a Studio 5000 project and generating an Autocad file based on the components in your...
863
PanelView +7 Series B ME station disables network adapter on panel when I downgrade to Rev. 9 or 10. Used to work before with the Series B panels...
497
Hi All What I understood from various manuals (e.g. rm094 & um543) is that you have the freedom to allocate any module to any slot. I understand...
659
