Add-On defined data type export/imprt
I’ve never done this, but you might try exporting the AOI then on the import dialog you might try going through the tree and tell it to delete everything but the new UDT. Just to be safe do it in an offline blank project file. If that works yout might be able to then export the UDT. Worst case, export the AOI, export a small UDT, the gut out the small structure from the second export and copy the AOI UDT from the AOI’s L5X file, using notepad or notepad +.
Add-On Defined and Module Defined data types are automatically added to the project when the respective add-on instruction or module are added to the project. There's no purpose to having a data type for an add-on instruction or a module that doesn't exist to be used - or at least, I can't think of one. What are you trying to do?
In any case, import your AOI and the data type will come with it.
I am trying to figure out how to use the predefined AOI, cant seem to find it in the manual for the add on instructions. Any help out there on a...
1,752
As the title says, all of the client HMIs at the plant freeze up for about 5-10 minutes everytime I or a vendor make new routines or new tags in...
44
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
152
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
158
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,276
