Add stringtext to multiple AOI local tags.
shauntieu
Sep 2011
fsdaf
I'm faced with a real time-consuming issue.
I have 100+ devices that uses 5 or so different AOI blocks. In our AOI blocks, we have parameters NAME and DESCRIPTION in the AOIs local tags.
I donno if its just me, but i find it very difficult to add/edit local tags for AOI.
1) I must goto the AOI scope (analogTransmitter_v3C)
2) select a data context (device using that AOI: _Temp_8345)
3) and only then am i exposed to the Name and Description parameters.
to set names and desciptions for 100 devices using this method is tedious and painful. I tried exporting all tags to CSV and manually editing the CSV, but the AOI local tags are not shown. :eek:
is there a better way or sneaky way to rename multiple AOI local tags?:confused:
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
130
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
129
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,093
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
599
