Adding a node to DH-485
Apr 2002
Just a bit northeast of nowhere
1,117
Greetings all!
I've got a point-to-point DH485 network running from a SLC 5/03 to a Panelview 600. I want to add a node to this.
My question is, what do I need to accomplish this wiring-wise? Do I need to add a 1747-AIC? Three AIC's? What exactly does the AIC do, anyway?
Thanks!
TM
Hi RS, thanks for the reply :)
I've already got that manual, thanks. What I'm trying to sort out is little grammatical tidbits like:
"You must install a link coupler for each non-isolated node on the network"
Does this mean if my device has it's own isolation I don't need a link coupler? Is the coupler serving some purpose besides just isolation?
Yeh, I'm being a cheap ******* here. I'm trying to do a little internal SCADA test, and keep it under $10K, so the $700+ for three 1747-AIC's is a bit more than I'd like to spring at this point.
Have you ever gotten away without using the couplers?
Thanks!
TM
Possible answer
I just got off the phone with Equustech, the guys who make the module I listed earlier. Their unit has built in isolation, and according to them, all I need is an RJ-45 Tee into the Panelview/SLC line and I'm ready to rock and roll.
I'll let you know how it turns out.
Thanks!
TM
I stated, but seem to have erased, that its a daisy chain trunkline system that you can "splice or tee into. I have never gotten to use an AIC that I can recall but have worked with a few DH and DH+ networks but it is my understanding that the 1747-AIC is required in some cases, using a KTX or KTXD card for example.
I was trying more or less to keep the thread high waiting on the AB guys to chime in.
Thanks guys!
RS, I find it reassuring that you've worked on DH-485 systems without the benefit of the AIC - it gives me hope I'm on the right track :)
Say, where'd all our AB guys go? Must be on vacation! :D
Tom, I saw the first link also, but the second was new to me. Thanks for pointing it out. Since my module has built-in isolation and it's own power, I think I'm covered from the issues they brought up there.
Thanks again!
TM
I have a question about adding another panelview +. We want to add a pv+ in the shop to monitor a line. The line currently has 4 other...
1,204
I have this machine that is communicating via DH+ to a central Logix PLC. This PLC has two DHRIO modules and we are already getting data from this...
23
3,976
We are adding two Motoman robots to a weld cell and I'm unsure how to get the omron PLC to configure the addressing?
2,809
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
64
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
144
