Ones_Zeros
Hello,
I'm still learning PLC programming and I was needing some help with
making some changes to our program.
I'm needing to remove the (TON) timer on rung 9
policies at work have changed to were once the (GRT) instruction sees 5%
it will shut the process down.
Overview of my Task:
At this point the process has seen 5% and it is shutdown, the O2
has to be below 5% to run. Now I have to start the process to give it a chance to
come down below 5%, so I want to hit a by pass button to start a 5 minute timer,so
the process has a chance to run for 5 minutes givining the O2 a chance to come down below 5%
if with the 5 minutes the O2 comes down the timer will stop and the process will start and
if during the 5 minutes the O2 don't come down below 5% the process will shut back down.
Here is were i need some help modifying the logic:
1. I want to delete the (TON) timer on rung 9
2. I added a new rung and I want to use the same input that is tied to the Reset Button (Local:3:I.Data.6)
3. when i hit the Reset Button, i want it to start a 5 minute timer
4. During the 5 minutes it needs to check what the O2 is reading by the (GRT) instruction on rung 9
5. If anytime during the 5 minute timer is goes below 5% i want it to shut the timer off and Latch the O2_SD bit back on rung 10 so the process would start back up.
(at this point you can't tell by the pic but the O2_SD would be un latched, so it would need to be re latched)
6. If during the 5 minute timer the O2 don't go below 5% it will shut the process back down, so it would nee to unlatch the O2_SD bit on rung 10
7. Someone would have to physically hit the reset button each time to start the 5 minute timer if the O2 don't fall back below 5%, thats OK.
Here is a sample of the logic:
I hope this makes since, this is probably simple to you guy, but I'm trying hard to learn this.
Thanks again for your help
