Adding a timer
Yes, the key switch on the front of the controller must in the "Remote Run" position. Then just go online make your edits.
First, let's assume the data table is currently set up to accommodate T4:0 to T4:10, for example. Now you want to add T4:11. That's increasing the size of the data table which I believe cannot be done "online". Actual timer usage has nothing to do with this either.
However, in the above example, let's say T4:5 wasn't used yet. You should be able to add a rung containing that timer in an online edit. (I will assume you know how to do an online edit.)
Deleted, sorry
Hello, I'm still learning PLC programming and I was needing some help with making some changes to our program. I'm needing to remove the (TON)...
3,949
Hello everyone, i have searched this forum and looked here for advice before but this time i wasn't able to find an exact answer for what i'm...
10,421
Does anyone know the best way to add a horn to a start button that stays on for 10 sec then shuts off and the motor starts.
7,168
Does anyone know the bet way to add a horn to a start button that stays on for 10 sec then shuts off and the motor starts.
3,209
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
88
