Adding AB SLC PLC to Fix32 V7
Hal9000
Jun 2010
London
140
Hi there,
I would like some advice in regard to adding an Allen Bradley SLC 5/05 to an existing Fix32 V7.0 installation. At the moment there is only 1x PLC connected to the SCADA, being a PLC-5
The configured I/O driver is ABR - Allen Bradley RSLinx v6.531
When I open the ABR I/O driver configurator, I can see channel 1 configured for the PLC 5.
Do I add the SLC 5/05 to Channel 2 and configure its primary IP address?
or
Do I select "add" a "device" on the channel 1 tab?
(see attached photo)
Once configured do I need to restart the Fix application?
Any other advice would be warmly welcomed.
Many thanks.
Justin
Hello, We have an older machine that has a standard PanelView (2711-T10C3) connected over DH485 to a SLC 5/04 PLC via a 1761-NET-AIC module in...
674
Hi all, First thing in the new year I'm off to a remote site to add a second chassis to an existing SLC installation. All of the hardware is...
4,554
Is it possible to add 1747-L541C to RS5000 so I can use message to get some float values? I am using 1761-ENI/D for Ethernet conversion on the...
9,057
Dear , problem : Adding and configuring analog input module 1794-IE8 to existing running system SLC 5/03 through 1747-BSN (DH485) System: - 2...
3,770
Currently we have a SLC 5/03 processor talking to a Panelview 550 via a 1747-AIC DH485 Link Coupler. What we want to do is add the ability...
3,666
