Adding ethernet/ip comms adaptor to logix system
chelton
Jan 2012
melbourne
325
Hi, Im wanting to add an ethernet/ip adaptor (an omron nx-eic202) to a logix system.
The Logix plc is a 1756-L61 Rev 15.4 with a 1756-ENBT/A Rev 3/1
I have Rslogix 5000 Standard edition Version 15.1
When I try to Add module, all i get is Allen bradley modules to select. I have added the EDS file with the rslinx hardware installation tool.
Do I need RSnetworx for Ethernet/IP or is there something im missing?
I've only done it once, and don't remember which model Omron Ethernet adapter I used, but if I remember correctly, you had to configure it as a generic ethernet module and set up as SINTs. You have to calculate how many SINTs you will have based on I/O. I remember there being a guide somewhere on Omron's website. Otherwise, your vendor should be able to help.
Have you already been through this?
https://www.myomron.com/index.php?action=kb&article=1671
If still no joy, configuring as a generic ethernet module is probably your best bet.
If yo follow this steps, I guess that an AOP for the Omron module is missing. See the step 2 how the NX is in the list. AOP is the Add-On Profile, an installable file that adds the respective module to the Logix "database" so you can pick from the list an add to the I/O tree.
Version 15 Studio and firmware is about ten years old. I know for certain it doesn't support EDS-derived module profiles, and it might not even support modern Add-On Profiles.
So if you have instructions on using a Generic Ethernet Module object, I recommend that you take that approach.
Thanks for the replies. Yes I have the quick start guide.
Short term I'm guessing I'll be using the generic module. Longer term the site should look at updating rslogix and the firmware.
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
147
Hi all. I'm having issues adding an ethernet module to my project in Studio500 v34. The device is a Fredericks Televac EthernetIP MX gateway which...
365
Hello I have a two controllers 1756-L61 and I would like to add an Ethernet Card module of one controller to the other one. When I search for...
883
Hello all, I am working on a project utilizing an s7-1200 cpu and Tia Portal v17. I currently have an external PCB with some sensors on it (and...
734
I am trying to add 2 controllers to each other via ethernet. One is to a conveyor system and the other to a skid that controls brite tanks and...
2,521
