Adding tags to existing logic 5000 controller
Robb B
Feb 2011
BC, Canuckistan
362
Hello everyone,
Adding a remote rack of cards to control logix, I've added the cards to the controller through the enbt module, and it creates those entries in the database OK. Now I've got the tag database exported in CSV format, and trying to add my 200+ new points and tags. When I try to import I get an error at the end saying "The CSV schema or Record line is invalid. Syntax error found while scanning import file."
Update: tried again but inserted new tags alphabetically, now each new tag shows error: one or more arguments invalid.
Rockwell is uncertain about the error as well. Hoping you can shed some light on this? I feel like I'm just missing something simple...
Well, not sure what I've done differently, now I have all my tags imported (except for duplicated names, need to sort those out). Solved!
You'll have to post the files so that we can also try it. Did you export your entire tag database, add to it, then try to re-import it?
Yes, exactly this. I copied the formatting and columns from existing tags. The only thing I can think of this time is to I added them in alphabetical location plus the bool data type AND the radix info.
I tried exporting the database, adding my approximately 300 lines of tags, then importing it back, but I've clearly missed something in the...
1,923
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
171
Hi PLCs.net! I'm using Studio5k V32, and I have an EDS file for the Fanuc 30r-ib plus controllers. I have an excel spreadsheet with bitwise...
1,447
I'm using a global DB as the i/o for some FBs (thank you, JesperMP). As I only need six bits for each FB I started with a byte as the input/output...
3,277
Hi all, I'm using Archestra SMC to manage tags in Wonderware Historian. I have an existing production line storing historical data, with maybe...
2,180
