Address and offsets
Jpk
Mar 2015
Naples
Hi to all, I am working with a GE Rx3i controller and I am programming some simple ladder logic. Having been trough an old manual for LD I have not understood how to add an offeset to an address.
For example I would would like to sum offset (10) to %R00010 and thus obtain %R00020.
Any hints?
Thanks in advance
Thank you Steve for you promt answer.
I got into Indirect referencing and understood the concept.
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
147
162
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
221
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
108
Hi Guys, Is it okay to have Redundancy ControlLogix Processor IP address set to DHCP? I had Static IP address on it but removed it via RSLinx...
252
