Address embedded I/O, MicLog 1500
Dave Sell
Nov 2004
How do I address the on-board I/O points on the MIcrologix 1500?
We will use the BWA model which I think has 12 inputs and 12 outputs, but I don't know from RSLogix 500 which bits these are.
I think it's O:0.1/xx but not sure - do not have a model here to test, couldnt find it in any manual or help file.
Thanks!
On input it goes I:0/0 thru I:0/11
Output depends on model but same basic idea O:0/0 - O:0/6
Even though your table show bits available they really are not all used.
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
75
140
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
212
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
106
Hi Guys, Is it okay to have Redundancy ControlLogix Processor IP address set to DHCP? I had Static IP address on it but removed it via RSLinx...
246
