addressing mitsubishi asi modules manually
Batchl3
Guest
B
I have very limited information on readdressing asi modules The information I have found states that you must readdress asi manually if you should lose severval of the slaves at once,creating a configuration error. How does one go about readressing the lost asi manually or by programming? The main plc is aFX248mt and the asi module is a 32ASI-M-AS
Hello, Batchl3;
I know of an As-i hanheld programming device, which allows you to connect directly to the As-i module and change its bus address. the one I used was sold by Siemens.
If you go to www.as-interface.com and do a search in Products for "Addressing and diagnostic units" you will find links to more than 20 different manufacturers of these As-i address programmers(none for mitsubishi, though).
On certain masters (from Siemens, in my limited experience), there can be certain functions that can change a slave's address on the bus, but these required a good deal of prudence (sometimes you would wind up with double addressing, which caused the bus to fail). These functionnalities vary from manufacturer to manufacturer.
Hope this helps,
Daniel Chartier
Hi Guys, I have a questions to the Mitsubishi guys about signal and module addresses. I’m coming from Siemens and Rockwell background, however...
1,204
950
Hello everyone, Looking for a little help, I have a simple project but I have not done very much analog with Mitsubishi... Its a Q06HCPU and...
3,473
Good day! i would like to ask about what are the analog addresses in mitsubishi plc..the siemens s7 300 plc has PIW and PQW.. what should i use...
1,860
Hi everyone, I hope you can help me with the following question: For one of our plants equipped with an MR-48-MR ES PLC we would like to access...
2,471
