Mitsubishi MX-48-MR ES: CPU Port Communication: Register addressing
Bucky2k
Jan 2013
Hamburg
Hi everyone,
I hope you can help me with the following question:
For one of our plants equipped with an MR-48-MR ES PLC we would like to access it via the programming/CPU port (PLC<-->FX-232AW<-->PC). We are already able to read write by using a very simple protocoll, however I am struggling to find out which hexadecimal address corresponds to e.g. the special registers D000-D999. I cannot find anything in the documentation. The CPU port communication protocoll is a simple text based one, only requiring STX - CMD - DATA - ETX - SUM. DATA contains only the internal plc address and the number of bytes to be read. Nothing in there to select if I want to read I/Os, M, C or D registers.
What am I missing?
Best regards
Sascha
Looking for Socket TCP/IP communications program examples for Mitsubishi PLC iQ-R R04CPU using GX Works3, to compliment the Mitsubishi Ethernet...
6,416
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
110
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
142
We have an A2USHCPU-S1 CPU with an A2SNMCA-30KE memory cassette. From the manual I've downloaded, it seems that the CPU is overwritten with the...
1,764
Hi, does anyone have experience with the Off Delay Long Timer function in GX works 3, I need a PV greater than T#2147483ms If I use Long Timer...
1,231
